Old Jan 27, 2013 | 06:30 PM
ijaved's Avatar
ijaved
Default Re: New Member - Need help
Thanks i did look there but couldnt find. I was in a hurry so will sniff through it again.
I drive a 6 speed, not sure I've heard of the auto-thing you are describing. What is "tip mode"? I HAD an auto for a time, never had any problem with it other than the common transmission-fluid-leak-from-the-electrical-connector that everyone else has at least once.
I THINK there is a thread here SOMEWHERE talking about removing the headlight assembly... doing a search with the search button might do it, or search the "exterior" forum for thread titles about it - is all you can do.
Other than that, it sounds like you better go here and download the SRT6 Service manual (applies 99% to the N/A-Limited-Base models):
https://www.crossfireforum.org/forum...ollection.html
You will never print it all, but it IS helpful. Just hard to search thru.
Sorry if i wasnt clear. I believe its called tiptronic where you have + - for manually shifting gears in automatic D. So it went to that mode and got stuck at 4 it wasnt even picking speed up could be a fail safe or something. It only happened once so I am hoping it would never happen again but wanted to see if anyone else had similar problem.
If someone out there used tiptronic shifting can you give me hinters ? how to get out of if without shifting to N or turning the car off?
