New Member - Need help
Old Jan 27, 2013 | 05:22 PM
ijaved's Avatar
Default New Member - Need help
Hi all, just got 2005 crossfire yesterday and need some help fixing the water in the headlight. I took out the top two screws but the assembly wont come out. Read somewhere that there's 2 more under the light whats the best way to get to it. Or bumper has to be removed to get to it? its the driver side.
Also car was in winter mode and it went into tip mode and got stuck in 4th gear. I had to pull to the side turn it off and turn it back on after which it was working ? is this a common problem or can someone point me to right direction to figure out what that was? its Automatic and i dont feel any problems when it is changing gears. I dont plan to drive it in winter was just bring it home from dealer. Outside temp was around -12 *C.
Old Jan 27, 2013 | 05:29 PM
bluecoupe's Avatar
Default Re: New Member - Need help
Welcome and follow the link: https://www.crossfireforum.org/forum...tml#post585345
Old Jan 27, 2013 | 05:51 PM
I drive a 6 speed, not sure I've heard of the auto-thing you are describing. What is "tip mode"? I HAD an auto for a time, never had any problem with it other than the common transmission-fluid-leak-from-the-electrical-connector that everyone else has at least once.
I THINK there is a thread here SOMEWHERE talking about removing the headlight assembly... doing a search with the search button might do it, or search the "exterior" forum for thread titles about it - is all you can do.
Other than that, it sounds like you better go here and download the SRT6 Service manual (applies 99% to the N/A-Limited-Base models):
https://www.crossfireforum.org/forum...ollection.html
You will never print it all, but it IS helpful. Just hard to search thru.
Old Jan 27, 2013 | 06:30 PM
ijaved's Avatar
Thanks i did look there but couldnt find. I was in a hurry so will sniff through it again.
Sorry if i wasnt clear. I believe its called tiptronic where you have + - for manually shifting gears in automatic D. So it went to that mode and got stuck at 4 it wasnt even picking speed up could be a fail safe or something. It only happened once so I am hoping it would never happen again but wanted to see if anyone else had similar problem.
If someone out there used tiptronic shifting can you give me hinters ? how to get out of if without shifting to N or turning the car off?
Old Jan 27, 2013 | 07:22 PM
bluecat1986's Avatar
if your in "tip mode" hold the shifter to the left to return to D. u should see this change on the dash as u use + and -.
Old Jan 27, 2013 | 07:35 PM
Mrmiata's Avatar
European car? Cause I push mine to the right to get in "D".. push left to downshift..
Old Jan 27, 2013 | 07:40 PM
Mrmiata's Avatar
sounds like you bumped it 1 time.. 4th.. bump again.. 3rd.. press and hold.. 1st from any gear.. press and hold to right.. back to D.. "bump" either direction selects next gear.. press and hold takes to end of selection range.
Old Jan 28, 2013 | 10:33 AM
rayth's Avatar
https://www.crossfireforum.org/forum...-assembly.html
Old Jan 28, 2013 | 11:33 AM
and the bottom bolts can be accessed through the little removable panels at the front of each wheel well with a 1/4" drive, long extension and I think a 10mm socket. ( and a good flashlight )
Old Jan 28, 2013 | 04:15 PM
sorry mr miata is right hold right to get in D left to downshift thats what i get for posting and trying to work at the same time
Old Jan 28, 2013 | 04:18 PM
Mrmiata's Avatar
Hey it happens.. lol.. I had to go back and edit that last post.. had your bump left in my head..
Old Jan 29, 2013 | 02:35 PM
ijaved's Avatar
I took it out last night and there's no way I can find the nut or screw with a long extension unless I knew what I was looking for and where. So I am thinking of just taking the jumper off doing it. Probably do it this weekend.
PS: Thanks for the Tip help. I will try it out when I take it out for a spin hopefully this weekend.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Apr 28, 2016 02:04 AM
steps
Apr 26, 2016 06:21 PM
Sep 28, 2015 07:40 PM
JEFASOLD
Sep 28, 2015 12:10 PM
