Old Jan 27, 2013 | 07:40 PM
Mrmiata's Avatar
Mrmiata
Default Re: New Member - Need help
Originally Posted by ijaved
Thanks i did look there but couldnt find. I was in a hurry so will sniff through it again.
Sorry if i wasnt clear. I believe its called tiptronic where you have + - for manually shifting gears in automatic D. So it went to that mode and got stuck at 4 it wasnt even picking speed up could be a fail safe or something. It only happened once so I am hoping it would never happen again but wanted to see if anyone else had similar problem.
If someone out there used tiptronic shifting can you give me hinters ? how to get out of if without shifting to N or turning the car off?
sounds like you bumped it 1 time.. 4th.. bump again.. 3rd.. press and hold.. 1st from any gear.. press and hold to right.. back to D.. "bump" either direction selects next gear.. press and hold takes to end of selection range.
