Old Feb 12, 2013 | 09:29 AM
ala_xfire
Default Re: New Longhorn Unrestricted DCAI
Originally Posted by Mrmiata
Figured I'd let the engine ingest some of the hot air around me (oopss.. that almost sounds like hating back).
Been logging my daily trips to and from work.. wanting to see how temps and cfm are vrs stock with K&N's. If I don't like what I see then they get moved to the front. Hot air rises to the top (Dangit.. Sorry Alaxfire)..
and this configuration sets the filters as far down as they can be.
Seriously, you might think about running them all the way down to the plastic belly pan, then possibly fabbing a plastic surround from the belly pan up for each filter after drilling some 1/2" holes in the pan inside the surround. This WOULD give them some cooler air inside the compartment.
oooh oooh - just thought - you could use empty 1 gallon paint cans for the surround with matching 1/2" holes cut in the bottom ...
