Old Feb 24, 2013 | 05:30 AM
  #101 (permalink)
Peter Arnold's Avatar
Peter Arnold
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Your pitures & step by step instructions on changing the Crossfire Headlamp bulb were most useful, but I had difficulty removing the plastic connectir plug from the old bulb. I finally did this by looping a thin plastic string around the back of the connector (like a lasoo), so I could pull it outwards, while wiggling it with my fingers! It finally came off, after which fitting the new bulb was no problem.
My main problem is Interior Noise, much louder than the Mercedes SLK on which the Crossfire is based.
Originally Posted by Mrmiata
Not a problem at all..
Now I have a question for the members.. If.. like in your case.. you don't have a clue whether your running 6000K .. 5000K .. etc. how would you know what to replace with? Granted they come in pairs so not like one white eye and blue eye syndrom... but if you wanted to keep what you had? I got the 6000K and they actually are bluer than what I originally anticipated..
