Old Mar 6, 2013 | 07:55 AM
maxcichon's Avatar
maxcichon
Default Re: Alt pulley removal without an impact?
I am not saying you did it wrong as long as the wrench was set to the max wrench setting and you did not exceed that setting.
I am suggesting that someone could get the idea that it is OK to use a torque wrench to undo nuts on an every day basis. Torque wrenches should be used as little as possible as after a lot of use they need to be re calibrated. A 24" breaker bar is cheaper than a new torque wrench.
I once saw a perfectly good Snap On torque wrench reduced to scrap metal when someone tried to break a rusted nut loose.
Using the right tool for the job is a good motto to follow to keep your tools in good shape.
Dave, the offender transformed that tool into another.
One designed, quite well I may add, for beating him about the head and shoulders.
"One mans scrap metal..."
