Alt pulley removal without an impact?
Old Mar 4, 2013 | 11:50 AM
latemodel21's Avatar
Default Re: Alt pulley removal without an impact?
"how much did those tools set ya back at lowes? " The ratchet, socket, and torx were around $35.
another choice is to buy the "Kobalt" 15/16 - 24mm (though-style) socket that is shown in gripgrip's pic (about $6.50) and turn it with a 7/8" wrench. You will, of course, need the T50 bit to secure the alternator shaft.
Chris
Old Mar 4, 2013 | 12:08 PM
To those that may be new to working on cars I do not think that the use of torque wrenches should be suggested as tools to remove bolts.
Torque wrenches are instruments and not tools meant to apply brute force.
Thanks for pointing this out, Dave I agree 100% !
If I gave the impression in my reply to grip (and pic of tools) that a torque wrench is a suitable ratcheting- breaker bar, it was inadvertently misleading on my part.
To be clear, while it may seem contrary to sound torque wrench practice, I did use it to break the alternator nuts free (on 5 different alternators) ... however, I was conducting a study of typical nut tightness (as I could find no spec for alternator nut torque setting to recommend) AND, I was only applying force until the "click" and then I was setting the wrench higher (until it broke the nut before it clicked) . As I indicated, I found 4 or 5 that came free between 70 and 100 and one that broke my T50 at 120 footpounds.
Another sound practice (of which I imagine you are familiar with) is to check the accuracy of your torque wrench(es) periodically.
Thanks again for your valuable input,
Chris
Old Mar 5, 2013 | 04:28 PM
grip grip's Avatar
Much cheaper option at Harbor Freight - only $19.99 for a full set.
http://www.harborfreight.com/21-Piec...tm_source=1003
Old Mar 6, 2013 | 01:01 AM
21 Piece SAE/Metric Go-Thru Socket Set
This set seems to lack the required 24mm or 15/16" socket.
Chris
Old Mar 6, 2013 | 07:24 AM
grip grip's Avatar
Chris
Oops.... That's my ADHD kicking in again..
Old Mar 6, 2013 | 07:55 AM
maxcichon's Avatar
I am not saying you did it wrong as long as the wrench was set to the max wrench setting and you did not exceed that setting.
I am suggesting that someone could get the idea that it is OK to use a torque wrench to undo nuts on an every day basis. Torque wrenches should be used as little as possible as after a lot of use they need to be re calibrated. A 24" breaker bar is cheaper than a new torque wrench.
I once saw a perfectly good Snap On torque wrench reduced to scrap metal when someone tried to break a rusted nut loose.
Using the right tool for the job is a good motto to follow to keep your tools in good shape.
Dave, the offender transformed that tool into another.
One designed, quite well I may add, for beating him about the head and shoulders.
"One mans scrap metal..."
usprb1976
Apr 4, 2024 04:57 PM
minimayhem
16
Aug 23, 2016 07:47 AM
smokey847
Nov 12, 2015 11:54 PM
jaesa
Sep 7, 2015 01:50 PM
williammt
Sep 6, 2015 11:23 AM
