Old Mar 6, 2013 | 06:41 PM
ala_xfire
Default Re: Top convertible problem
Originally Posted by Dragoncross
also another thing i notice was that when the top its in the closed position i mean secure in the windshield and all doors closed windows up and the car with the engine on i press the button and the windows wont go down, actually the light on the button is blinking not steady... i have a lot of problems then maybe the module is bad has anyone had one before gone bad????
Pressing the top down button with the windows up and the top locked will NOT lower the windows. You must momentarily press the top switch in the down direction for about 1/2 sec, then release, then press and hold. Same for windows up.
Do your windows go down if you unlatch the top with the ignition on ? ( They should, if they don't, then check the front bow switch that is on the right hand latch assembly )
