Old Mar 6, 2013 | 07:08 PM
Dragoncross's Avatar
Dragoncross
Default Re: Top convertible problem
I asked if you have enough oil in the system in post #2 and no answer so I will not ask if you still have air in the system. I'll leave that to someone else to ask.
im sorry i didnt answer that one! yes i do have enough oil in the system actually the i check it out before i try to operate the top, and the leak from the cylinder was minimum a few drops form within the shaft, Top Hydraulics fix those cylinders and as for the how i refill the pump i refill it with a hose and opening the screw on the side of the reservoir.
