Old Mar 12, 2013 | 09:52 PM
  #224 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!
Originally Posted by Timesnow
Couldn't agree more been there to many times myself. Just a number of how many did, curiosity you know.
So the data-logging, is that kinda like putting the car on a dyno but your actually on the road instead of standing still on a roller?
Yeah I'd like to see that we all came through and got a bargain.. but..
The name of the sensor required eludes me right now.. but it is "accurate" AFR readings. My understanding is LAMDA (which will be used without the addition of a sensor) is a calculated AFR. Otherwise the numbers will be off the sensors and even then some would be calculated. Example being Torque Pro. It gives me 0-60 ET and HP and Torque, but they are calculated. I just look at it as a means of a baseline and anything done to the car can be compared to that.
