Re: Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!
You most likely have a bad cable or port or drivers not loaded. Just plugged mine in for grins and started the program.. 5 seconds later turned green.. cable detected. You can play around.. uninstall.. download from link and re install.. try XP mode .. or call the guys at the shop.
