rmcdaniel12
Thats the exact reason why i purchased the tune- from all the good reviews ive heard. I bought the 74mmTB prior to the tune and thats when i got the lean codes. I then purchased the eurotune hoping that the 'computer guy' could resolve the issue. I dont have many mods that differ from your setup. Other than K&N stock replacement filters and the bigger TB, all my other mods have juwt been air restriction deletes to the stock setup. Its not like ive done any extensive engine work here.
Tune is not going to fix an issue.. I haven't seen where anyone has had code errors from the stock tune after a throttle body upgrade. You have other issues.. new gasket at throttle body?...bad seat on a vacuum hose?..crack on a vacuum hose?....Used a torque wrench at install or "feels about right"..? Use propane around the area and see if it picks up idle.. oh... don't light it first.. LOL. And if I'm not mistaken seems I've read issues from just the seal on the engine cover not being good. And let's not forget we are buying USED throttle bodies... no chance of a defective one there..
