Old May 13, 2013 | 11:11 PM
  #429 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: Eurocharged Euro-Flash! Data Logging, OBDII Code Functions, and ECU Flashing!
New gasket w/dab of sealant to hold in position... properly torqued ... old maf sensor.. vacuum lines securely in place... and a throttle reset. You should be good to go without issues.. If this list is all "checks" well we are using "used" throttle bodies. I doubt a tune is going to straighten things out for you.
