Old Jun 1, 2013 | 06:38 PM
ala_xfire
Default Re: Drive shaft flexible disc
Originally Posted by Abaton6
Why would MB use this instead of a u joint? The u joint seems like it would be stronger, and more durable.
A U joint is generally used in a scenario where there is a large degree of angle varience between two spinning components in one plane. In the case of our cars, there is very little difference in alignment between the components, the flex disk is more for smoothing out the shock transients between the transmission and the differential.
A U joint has no value in shock dampening.
Of course, that's just my opinion, but I stick by it......
