Old Jun 5, 2013 | 09:32 PM
dinasrt's Avatar
dinasrt
Default Re: New ic pump, same problem now what
Originally Posted by Raicerx
I just purchased a 2005 srt6 with 60k miles on it. When test driving I noticed a distinct loss of power at times. Having experience with forced air motors I sensed a faulty blower, after researching and reading the numerous posts on faulty cooler pumps I replaced mine after committing to the purchase of the car. At first I thought the problem was fixed, however upon driving a bit more discovered the problem still exists. I can feel, while cruising, what I suspect to be a disengagement of the clutch that drives the blower shaft after the engine warms up. I get a brief drag or surge when driving a steady speed at random moments. The feeling is similar to the feel one gets when an ac compressor engages and disengages on a 4 cyl. motor while driving. I do get unbelievable power in the first 5 minutes of driving and can drive the car hard without issue. Once the engine temp gets to normal operating range, the blower works intermittently. I feel it is definitely heat related. So the question is, do I replace the temp sensor next? Any other thoughts? Once done there I would like to pump up the performance any tips here?
My first thought is that your replacement pump isn't doing its thing either. What did you replace it with? Did you verify that it energized and ran O.K. before you installed it? And then yes, the IAT sensor.
