Old Jun 9, 2013 | 11:14 AM
oledoc2u
Default Re: New ic pump, same problem now what
Originally Posted by Bogart1
I am curious and ignorant, how does one "burp the system"? I am going to change out my old I/C pump for a new BOSCH pump and I want to do it correctly the first time since it is bit labor intensive. Thank you in advance.
After refilling the radiator, you need to let the car run up to temp with the cap off the radiator. If you were to watch you will see the water/antifreeze mix burp letting out air. When air leaves usually you will see the water level drop. You add more mix until full. Cap it drive it, watch the temps. If it over heats, let it cool and repeat the procedure.
