Old Jun 9, 2013 | 11:18 PM
syfi's Avatar
syfi
Default Re: Cheap tie rods at Tractor Supply
I only see one nutted adjustable end. Also the width of the barrel may make contact with the brace that the oem bracket curves around. And the ball socket ends are normally non-articulating and have poly or urethane inserts to help eliminate squeaking. You'd probably have to apply some thick inserts/washers on each side of the socket ball to lock it down and grease the heck out of it. Just going from the size of the ones I used that were a near perfect fit!
https://www.crossfireforum.org/forum...tml#post712854
