Old Jun 18, 2013 | 12:52 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Cheap tie rods at Tractor Supply
Originally Posted by syfi
I only see one nutted adjustable end. Also the width of the barrel may make contact with the brace that the oem bracket curves around. And the ball socket ends are normally non-articulating and have poly or urethane inserts to help eliminate squeaking. You'd probably have to apply some thick inserts/washers on each side of the socket ball to lock it down and grease the heck out of it. Just going from the size of the ones I used that were a near perfect fit!
Attachment 28577
https://www.crossfireforum.org/forum...tml#post712854
So these are the ones you used for your set up 7 months ago?
91008001-STR..... FORGED STEEL 4-BAR END RH..... 2..... $12.99..... $25.98
91008002-STR..... FORGED STEEL 4-BAR END LH..... 2..... $14.99..... $29.98
How do you like them? What kind of noise do you have if any?
