Old Jul 8, 2013 | 09:38 PM
oledoc2u
Default Re: No start over 1 year later help
Originally Posted by nayel09
If I had no fuel pressure wouldn't it set a code on the scanner I have no codes I don't know what I got my self into with a rebuilt crossfire ..
NO...if you have no fuel, you don't start. When you stated you can get it fire by putting starter fluid in the throttle body, you answered your own question. NO FUEL. It has sat for a year. PUMP may not be priming, Air in the line, plugged line, no power to the pump, etc. The line might not even be on the car for I know. YOU have to get under there and start where the fuel starts. The filter and the pump. If you eliminate you have fuel flowing to the front of the car, then on to the next area to look in...
