No start over 1 year later help
Old Jul 21, 2013 | 08:31 PM
  #41 (permalink)
Default Re: No start over 1 year later help
You have got to see if you have power leaving the RCM - if you do, then it's in the wiring - if you don't, it's in the RCB.
If it's the RCB,then either bad solder somewhore or a crappy relay.
I gave you the link to the manuals, go download the SRT Service Manual! (Don't worry, all the cars are so similar, the SRT manual will work for you).
Around page 8W-10 you will start seeing the diagrams of the RCB... you can find the -pin the power leaves the RCB on and measure it - if you have nothing there, then resoldering the RCB is needed. If that does nto do it, the Relay is bad.
I'm in Oklahoma the next two weeks - I won't be a LOT of help unless we have a lot of downtime due to weather!
Old Jul 21, 2013 | 09:47 PM
  #42 (permalink)
nayel09's Avatar
Well I found the wire coming out from RCM to power the pump the green and red wire I cut a piece to be able to test with volt meter and I got nothing the red ones dat go in to the RCM do get voltage wats the rcb
Old Jul 22, 2013 | 12:47 AM
  #43 (permalink)
rekcah's Avatar
isn't the fuse for the pump #4 and not #5?
The blue one that is right next to the amber one?
Old Jul 25, 2013 | 06:55 AM
  #44 (permalink)
nayel09's Avatar
I tested all fuses they all have voltage but wen I test the wire coming out of the RCM to fuel pump I get nothing is there a possibility it can be my cranck sensor not sending power to pump.?
Old Jul 25, 2013 | 07:05 AM
  #45 (permalink)
If the wire to the pump is not going to 12v, did you test the wire that tells the fuel pump relay to energize ( from the PTCM ) ?
The fuel pump relay is supplied 12v by the engine relay in the RCM, and then the PTCM supplies ground to the other side of the coil when it wants the pump to run.
Here is the diagram :
Old Jul 26, 2013 | 05:59 PM
  #46 (permalink)
nayel09's Avatar
Yes I the pins that are coming into to ther relay wich ther is three red all get 12 volts but the Green and red has no voltage I dnt get it my RCM looks good all solders are clean we're is the rcb anyone .
KDW4Him
18
Sep 1, 2021 05:47 PM
JEFASOLD
Nov 14, 2015 10:39 PM
gtjl
17
Jul 22, 2015 06:28 PM
cx24724
Jul 12, 2015 11:57 AM
bdh
Jul 9, 2015 09:40 AM
