Old Jul 10, 2013 | 02:35 AM
ala_xfire
Default Re: No start over 1 year later help
Originally Posted by nayel09
Finally looked under found rust everywere terminals on pump corroded tried to remove clamps in Aline but clamps are different do I need a tool or break them and use regular ones
The OEM clamps can be reused ( with care ), but most replace with fuel line screw clamps.
To release the clamps, there is a little hole in the center of the clamping area, you can get a tiny screwdriver or something pointy in there and pry the outer portion of the clamp up to release it. To put them back on, a pair of standard pliers will do the trick.
