Old Aug 17, 2013 | 08:49 PM
pizzaguy
Default Re: Need Help Felllas
Originally Posted by SrWilliams
If the above is not the case, how do you guys suggest i go about hooking the tweeters to the head unit and the door subs to the amp (if the tweeters and subs operate off of the same wires)
Any help will be greatly appreciated.
Run your own wires from the tweeters to the head unit! It is not as hard as it sounds, but it will take most of the afternoon to snake the wires thru.
Keep polarization in mind - + on the speaker goes to + on the head!
Also,
I understand you are using the factory speakers behind the seats, you didn't change them, did you?
Oh, and thanks for buying Kenwood!
Mark Christopher
Kenwood USA - Systems Group
Suwanee, GA
