S. Artee
In fact, i removed the screw and the "washer" easily, but now, the pulley won't come out of the shaft.
I sprayed a lot of WD40 on it, and i do same each time i pass close to the compressor which is actually out of the engine.
The pulley simply refuses to extract.
When i see the Code 3 tutorial to remove the pulley, it seems as easy as ABC !
But for mine : it is probably oxyded, and for now, i don't really know what to do.
If someone has an idea, or did the trick with a special tool, please tell me.
Thanks !
