Old Sep 12, 2013 | 07:30 AM
DTMenace's Avatar
DTMenace
Default Re: Door Speaker Question
Originally Posted by Penniman
Hey guys I've done a little searching but haven't found the answer to my question so I apologize in advance if this question has been answered before. I would like to replace my door speakers but most aftermarket door speakers are 4 ohm independence and I know our system is 2 ohm. Now if I buy 4 ohm speakers will it mess up the amp at all? and I know when you go lower in independence that your wattage doubles. So if our factory system puts out 35 watts at 2 ohms and I buy 4 ohm speakers rated at 70 watts or more should I be okay?
Thanks to all who have took the time to read this and hopefully someone can help me out on this.
Penniman
Before you change your speaker in the doors, you may want to read the the thread below, that was authored by pelked1 several years ago. This one will save you $, since the cost is less than $2.00 and will provide a much improved performance from the existng speakers. It will drastically reduce the base boom with the standard set up. Just read some of the responses from other members, including myself on this subject.
Just my 2 cents....
Dennis
DTMenace
https://www.crossfireforum.org/forum...-buck-mod.html
