Re: Check engine lights
cookiemonster131
ok reading that seems like the RCM usually cause a no start problem. would this still be the problem if the car runs it may be a bad solder joint in the RCM?
Yes. Starting here :
https://www.crossfireforum.org/forum...0410-code.html
will lead you to the RCM. It is an easy fix so that is where I'd start.
Reason: wrong link at first sorry!
