Throwing a P0410 Code
Old Jan 26, 2012 | 07:52 PM
God_Likes_Tebow's Avatar
Default Throwing a P0410 Code
just open to suggestions and I have been doing my research on it, so Im not asking like a n00b.
I know its the Secondary Air Injection pump. MrMoPar has been gracious enough to send me a stock check valve, aftemarket check valve, and a solenoid for a potential fix. Gonna give that a whirl to see if it fixes the issue. Also need to check my fuse as well before moving onto the actual pump replacement.
Just seeing if you guys had anymore insight on this issue. I notice when it rains the car exhaust system seems plugged up with a odd sound to it. My guess is water is being sucked back up into the pump through the exhaust. Could be an entirely whole other issue?
Old Jan 26, 2012 | 09:09 PM
6000rpm's Avatar
Default Re: Throwing a P0410 Code
Welcome to the forum!
It sure could be the air pump, but a lot of folks on this forum had the P 0410 code and it turned out to be the Relay Control Module. It's common to have bad solder on the circuit board.
Try this link:
https://www.crossfireforum.org/forum...-no-start.html
Good luck!
Old Jan 26, 2012 | 09:40 PM
tighed1's Avatar
Try this link:
Good luck!
Ditto on the WELCOME!
Check the relay in this post from the above link.
This will cause the PO410 fault.
Originally Posted by tighed1
PLEASE remember that you need magnification to see the bad joints.
Don't want someone to look with the naked eye and think all is well.
You don't need magnifcation to see the problem some are having with the Air Pump relay. Checkout these pics.
Should look like this:
It's relay #5 in this picture from onehundred80.
Old Jan 27, 2012 | 01:22 AM
Awesome pics Tighed1! Much appreciated.
Now u raise a good point on the RCM because I actually had that replaced by a new unit because my other one was done and I did start occurring these issues afterwards, so maybe it could be that.
I'm going to check the valves first because the way my exhaust starts to sound I doubt its the RCM causing it which makes sense that water is somehow possibly getting into the air pump causing it to possibly stall? None the less I have to get this issue fixed, so Im trying other alternatives before I have to take it to the stealership. Ill check the air pump fuse to see if possibly its blown which I havent done. Ill keep this thread updated for future reference.
BTW, thanks 6000 much appreciated amigo.
Old Jan 27, 2012 | 06:00 AM
6000rpm's Avatar
You're welcome! But Tighed1 sure knows his stuff!
Good luck with that air pump.
Old Jan 27, 2012 | 09:07 AM
MrMoPar's Avatar
I did not want to blindly sell him a pump, so I loaned him an aftermarket check valve, stock check valve, and stock solenoid first. If those are ruled out, fuse is good, relay turns out okay, then time to order the pump.
Old Jan 27, 2012 | 09:27 AM
rmaier's Avatar
Your a good man MrMopar...........Nice to have you around!
Old Jan 27, 2012 | 12:53 PM
I agree Maier! Much appreciated it again!
How would I know if the RCM is working properly if its already been replaced by a new unit? Recheck the contacts?
Old Mar 13, 2013 | 12:48 PM
wraith13's Avatar
Got the p0410 code....checked the relay, touched the relay together, pump runs....tighed1 recommended this is another thread.....check valve is replaced....what else could cause the cel code
Old Jan 6, 2015 | 06:29 PM
atlsrt44's Avatar
Well My xfire is now throwing this code.
Re soldered the relay (which looked horrible) and the code went away for about a week. Don't know that the relay can be fixed if that is even the problem.
Any suggestions?
Old Jan 6, 2015 | 06:38 PM
MrMoPar's Avatar
The solder connections are a symptom of the larger issue. If you take off the little spring on the contact plate, and slip the plate out of the relay (copper wire stays attached), you will see that the contacts are sooted black and burned away. I suspect that the relay used is not rated high enough for the actual current draw. If the contacts are damaged bad enough, the fix is to replace the relay or the entire module.
Old Jan 6, 2015 | 06:40 PM
atlsrt44's Avatar
any idea where I can get one?
Old Jan 6, 2015 | 06:44 PM
MrMoPar's Avatar
I am looking for a replacement relay.
Old Jan 6, 2015 | 09:10 PM
philosophico's Avatar
If you want to replace the RCM with a new one here you go.
RELAY. APPARATUS CASE AND CONTROL UNITS for Mercedes SLK 32 AMG KOMPRESSOR (2001 - 2004). #1705450305
I remember going through this, in the end I just replaced mine and been fine. This will fix it for certain, that much I can attest too. German cars are more finicky about there electronics then say your domestics. My ram srt-10 will run fine with no name sensors from autozone, my srt-6 with throw a fit if its not OEM/Bosch.
Old Jan 6, 2015 | 10:14 PM
YOu can buy the relays for around $3.10 each plus shipping. THey solder right in. I bought 12 last summer and sold six to a guy in Mexico.
100/80 has posted the link to where you can buy them (and where I got them). Just can't find it now.....
Old Jan 6, 2015 | 10:21 PM
See post 1:
https://www.crossfireforum.org/forum...ement-rcm.html
Old Jan 7, 2015 | 06:19 PM
atlsrt44's Avatar
Ordered the RCM. Do I need to order some relays as well?
Old Jan 7, 2015 | 06:26 PM
Unless you ordered a USED RCM, it will come with all new relays soldered in.
Old Jan 16, 2015 | 02:46 PM
atlsrt44's Avatar
Replaced rcm today. Problem solved
Old Jan 16, 2015 | 08:42 PM
Glad to hear.
