Old Oct 27, 2013 | 06:37 PM
  #627 (permalink)
onehundred80
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by laminad
I am in the middle of this procedure and made it to the end where the assembly is out and the latch is open. When I opened the latch, I did not see a pin or spring. My question is how obvious is this spring and pin? Will it shoot out of the opening once the latch is open? I'm guessing either I've done something wrong or the previous owner has already completed it. Thanks to anyone with info.
If there is no spring or pin under the cover then you can be assured the PO removed it.
