Old Oct 28, 2013 | 01:21 PM
  #632 (permalink)
onehundred80
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by KDW4Him
If the PO was there before you the cover would be really dented up because the same cover goes back on at the end of the procedure.
A group in southern michigan found two 2008's that didn't have the pin! I wonder if Laminad's car (if it is not a 2008) has had a replacement ignition lock put in and I wonder when the mfr. started leaving out the precious pin & spring? The pin that would come out would look like these..... https://scontent-b-ord.xx.fbcdn.net/...68269208_n.jpg or this one.... https://scontent-b-ord.xx.fbcdn.net/...73855135_n.jpg
I had forgotten this, it arose earlier. I will remember in the future.
