Old Nov 11, 2013 | 01:18 AM
  #291 (permalink)
corfire's Avatar
corfire
Default Re: Do you want a Keyless Entry Alert Tone?
Originally Posted by Rets
I did this today and now the car locks by itself inside or outside the car? I have the neg going to 86 what else could I have done incorrect?The chirp works when I lock and unlock with fob?
Just took it out and the door locks are not locking!
I liked the chirp but what could have caused the doors and trunk to lock? Glad I kept the windows down the locks would lock with fob inside on seat
Again
Neg to 86
pos to 85
Took out fuse as instructions recommended and it worked fine except the doors would lock 2-3 min after I unlocked them
I think that maybe the Crossfire has tricked you. If you lock the doors with the fob and then unlock them without opening a door, they will re-lock automatically in a few minutes (not sure how long). You must open a door for them to stay unlocked. It has a German mind of its own! I was originally confused by this feature also.
I am not sure what you took out, but if you removed the relay the locks probably won't work. It sounds like you had it wired right if it was chirping?
