Old Nov 12, 2013 | 12:20 PM
  #83 (permalink)
Mrmiata's Avatar
Mrmiata
Default Re: Radio help limited coupe 2005
Originally Posted by redfire2005
Hello Help
I need options> I replace CPS car was working fine until I shut it off. I came back turned the key and it started - then stopped, Did the same again start and stop, on the 3rd try got all the dash lights and no crank.
Days following I cleaned the CPS, reset the connections (try to get in to it and couldn't) module with printed wiring circuit, I got the same response as above - 2 tries but this time no start just crank 3rd time again dash and nothing. I am thinking fuel pump?
Please help and thanks for your endless help
I'm hoping you were also playing around under the dash.. and knocked the wire off the transponder ring on the ignition that reads the rfid chip in the fob.
If not you really need to search " skreem " . And this is typically not good news. There has been a fair amount of this lately.
