Old Dec 29, 2013 | 11:50 AM
boostmonkey's Avatar
boostmonkey
Default Re: Ultimate fuel rail
Originally Posted by JesseJamessrt6
I like the design of your rail system, good job Matt!
Any pics of the new fuel feed 8AN line?
Thanks!!!
I don't have it installed yet. My car is put away in the barn for the winter. Pics will have to wait until spring.
Originally Posted by MoparFreak69
Just a thought/idea/hint/$.02 about those AN fittings. They are the exact same thing as a hydraulic JIC fitting, which can be bought from a hydraulic supply store for WAY less than those super nifty AN fittings. Heck you would probably find it cheaper to run hydraulic hose that is gasoline compatible than the SS braided stuff you are all using. Sure, it may not look as pretty, but I would take 4 braid 4000+ PSI hose over some teflon tube surrounded by 2 SS braids any day of the week. Also consider the heat rejection benefits the thicker rubber hose will have over the SS stuff.
The funny thing is, I actually asked about it casually when I was at a hydraulic supply store picking up some stuff for work recently (for big engines, 2500 HP continuous rating). They said they could order hose that would work. Will JIC fittings attach directly to AN fittings?
Originally Posted by lildaddym
Would this be a worthwhile mod for us NA guys?
Originally Posted by oledoc2u
I wouldn't think so.... As we add more boost (air), we need a higher volume of fuel delivery at peak operating rpms...
I agree. The stock fuel rail (and likely entire fuel system) is sufficient for NA cars.
