Ultimate fuel rail
Old Dec 27, 2013 | 04:41 PM
Default Re: Ultimate fuel rail
I machined steel fittings to press in the ends and used silver solder.
If you press fit parts together the melted material will not go between the surfaces and you can end up with a joint that is as strong as the press fit and the strength of the brazing material in tension which is not much at all.
Brazing, silver brazing in this case and soldering rely for strength on shear strength not tensile strength.
As the video says the correct silver alloy used is important, you can get solder containing silver and it is of no use for this job.
When the joint has to be above 840°F (450°C)for filler material to flow it is brazing, below that temperature it is soldering.
Old Dec 27, 2013 | 04:52 PM
tunaglove's Avatar
Yes you are right. Not press fit, push fit I should have said. The process was like sweating water pipes in your home. I had to heat the rail almost red hot. I think the inlet in the center of the rail like boostmonkey did would need to be welded. Cool project boostmonkey!
Old Dec 27, 2013 | 06:21 PM
boostmonkey's Avatar
"You can't fit dual 3" aluminum intake tubes around the radiator."
"You can't weld aluminum sheet with a MIG."
"You can't fit 8AN fittings on the end of the fuel rail."
"You can't weld thin wall pressure tubing with a MIG."
I've heard it all. The thing is, I am move of a "I can" kind of guy than "I can't." I'll find a way.
Originally Posted by 32krazy!
matt i hope to save you some hassle but an8 male fitting with a an8 90* fitting WONT fit behind the recirc valve.
I think it will. I did measure. Notice the short-radius 90* swivels on my sketch. AN hose ends are not the first fittings connected to the rail.
the only way there was enough room was to cut the rail at almost the injector hole
Yep.
its easier on the pass side if you leave the bend in the rail.
I agree. I did.
weld away but i dont know of a single fabricator that uses mig on a fuel system. the only way to properly control the heat is to use a tig
This is what I would tell you also if I were a fabricator with expensive equipment trying to sell you my services.
something to consider is how my new fuel system will be routed. out of the tank with an8 splitting into 2 lines to the filters then a y to a single an8 to the rails and using 2 rails split again and feed each rail individually. back thru a y into the fpr and a an6 return line to the tank
That's four Y fittings! The good ones are ~$50 each. The reason I installed the inlet fitting in the back of the rail rather than cuting the rail in two was to avoid buying one Y fitting. This isn't the Porsche forum. It's HP/$ here, not HP/HP.
I do REALLY appreciate you sharing your advice and former SLK experiences with me Steve. In fact, you've been more help than anyone! (except for the local wrench-turners) But you should realize by now that I am going to build an SLK32 that is faster than yours was, for a fraction of the cost.
Next thing you guys are going to tell him is to build it out of silver, even it cost 5 grand. Obviously he owns what he owns (MIG), and I don't see people lining up to build these at an affordable price.
Thanks Anthony. I BUILT one for me. I'm set. I posted the information, instructions, and offered my services (not free of course) to anyone else interested in a better fuel rail at below-unobtanium prices. I am not a consistent poster, but I do try to share what I have learned or done. 12.2 and not even tuned yet.
by your theory may as well just use a garden hose to run the fuel. my .02 was tig was what the pros use and who wants fuel to leak at the injector? i know matt has a mig and from looking at the welds he has miles to go before i would trust the welds to hold. again this is just my .02 and i think matt is an awesome wrench
They'll hold. Nothing I weld leaks. What pressure do you think I should test them at? 150%? 5/3 like DOT testing for cylinders?
THANKS!!!
Old Dec 27, 2013 | 06:25 PM
Nice video... With the spare fuel rail, we ought to be able to come up with something similar... thanks for sharing....
Old Dec 27, 2013 | 07:57 PM
32krazy!'s Avatar
you cant fit 3" without cutting the sorround. thats not a "i cant" but rather im willing to hack the car up
from your sketch you show a an8 90* fitting at the end of the rail. i already tried a hard 90, a swivel 90 and a radiused 90. none of them fit . a hard 90 in an6 fit if i shaved a bit off the recirc valve. just telling you what i already tried but swing away batter
im not selling anything. but i have been around this enough to know what fabricators use and a mig isnt it. i understand your using what you have
its going to take more than fuel rail to do that!! you should be grateful thats not a stick your driving!
test it until it bursts so you actually know what it will hold. if your going to sell them you put yourself on the line for all the stupid stuff people do, whether you want to be or not
THANKS!!!
i hope you get what you looking for. just understand bruce and i spent over 6 months and hundreds of $ in lines and fittings, s/s braided line to make the ttm rail. it wasnt done overnight
Old Dec 28, 2013 | 01:25 AM
JesseJamessrt6's Avatar
I like the design of your rail system, good job Matt!
Any pics of the new fuel feed 8AN line?
Old Dec 28, 2013 | 08:49 AM
BTW...I appreciate how hard it is to weld something that small and tedious with a MIG. I do have a TIG available to me, but brazing appeals to me too. We had to use that method long before TIG, or MIG was available. Either way, it is another idea in rethinking the fuel delivery. Thanks again...
Old Dec 28, 2013 | 01:13 PM
MoparFreak69's Avatar
Just a thought/idea/hint/$.02 about those AN fittings. They are the exact same thing as a hydraulic JIC fitting, which can be bought from a hydraulic supply store for WAY less than those super nifty AN fittings. Heck you would probably find it cheaper to run hydraulic hose that is gasoline compatible than the SS braided stuff you are all using. Sure, it may not look as pretty, but I would take 4 braid 4000+ PSI hose over some teflon tube surrounded by 2 SS braids any day of the week. Also consider the heat rejection benefits the thicker rubber hose will have over the SS stuff.
Old Dec 28, 2013 | 01:45 PM
lildaddym's Avatar
Would this be a worthwhile mod for us NA guys?
Old Dec 28, 2013 | 04:18 PM
I wouldn't think so.... As we add more boost (air), we need a higher volume of fuel delivery at peak operating rpms...
Old Dec 29, 2013 | 11:50 AM
Thanks!!!
I don't have it installed yet. My car is put away in the barn for the winter. Pics will have to wait until spring.
The funny thing is, I actually asked about it casually when I was at a hydraulic supply store picking up some stuff for work recently (for big engines, 2500 HP continuous rating). They said they could order hose that would work. Will JIC fittings attach directly to AN fittings?
I agree. The stock fuel rail (and likely entire fuel system) is sufficient for NA cars.
Old Dec 29, 2013 | 05:16 PM
JIC has 37½° taper, what is the AN? SAE is 45°. Curious about AN, I don't know.
Old Dec 29, 2013 | 05:22 PM
Ok I just found this site: AN Fitting Guide - anfittingguide
In the download guide It says AN sometimes is referred to as JIC.
Old Dec 29, 2013 | 06:22 PM
I downloaded this. (CLICK)
AN and JIC being two different standards.
Old Dec 29, 2013 | 06:28 PM
AN is a JIC fitting produced under tighter tolerances for Aviation use. We are talking temperature extremes that require a very tight fit for proper sealing. They are the same 37* flare, same thread pitch and everything else, the JIC is just the industrial equivalent that isn't rated as highly. For use in machinery and automotive environments it is overly sufficient.
Old Dec 30, 2013 | 11:45 AM
Default
Thanks for the info!
Old Apr 25, 2014 | 03:31 PM
The Ultimate Fuel Rail is done!
It works great! No leaks, pressure tested at 100 psi. I have a few hundred miles and many dyno pulls on it. Here are some pics.
New center 8AN inlet.
Passenger-side 8AN outlet, 90, and reduction to 6AN line to AFPR.
Driver's side 8AN outlet, 90, and reduction to 6AN line to AFPR.
But wait a minute... an 8AN fitting WILL NOT FIT on the driver's side end of the rail, right?
What is going on there?
The 8AN 90* elbow coming off the welded fitting did in fact hit the air injection valve. But I said I would find a way to make it work didn't I? So I cut the air injection valve in half. I found that a 1/2" aluminum pipe was a surprisingly perfect fit inside the outlet of the valve. I brazed a section of the aluminum pipe to the halves of the valve with some low-temp aluminum rod and a MAPP gas torch, thus extending the valve forward and out of the way. Everything fits great now. No codes, no leaks.
Old Apr 25, 2014 | 03:53 PM
  #38 (permalink)
tunaglove's Avatar
I had Boostmonkey weld the rear fitting on my spare rail and his work looks great. Thanks!
Old Apr 25, 2014 | 03:57 PM
  #39 (permalink)
dinasrt's Avatar
Wait.. You're pounding fuel in from 3 locations? This thread should now be XXX rated.
Very industrious work there, nice job.
Old Apr 25, 2014 | 04:10 PM
  #40 (permalink)
no, he has 6AN inlet feeding the back center of the rail, then on each side at the rear of the rail are teh return lines to the adjustable regulator. great set up!
