Ultimate fuel rail
Old Apr 25, 2014 | 04:18 PM
  #41 (permalink)
dinasrt's Avatar
Default Re: Ultimate fuel rail
Originally Posted by JesseJamessrt6
no, he has 6AN inlet feeding the back center of the rail, then on each side at the rear of the rail are teh return lines to the adjustable regulator. great set up!
I should have read and paid closer attention. I was able to pick up Anthony's TTM rail and a new sl55 pump and look forward to better FP. But his setup will no doubt flow great w/ less bottleneck.
Old Apr 25, 2014 | 04:22 PM
  #42 (permalink)
JesseJamessrt6's Avatar
Matt, are you controlling the regulator to adjust fuel pressure? If so, how?
the set up looks something like this but I think Matt has a better picture or diagram;
Old Apr 26, 2014 | 05:53 AM
  #43 (permalink)
32krazy!'s Avatar
try to remember that upping the fuel pressure on a oem fuel setup i.e.: fuel lines won't help that much. its like hooking an air compressor to a straw. diameter is still to small. add pressure to a garden hose now you have the needed fuel! for most set applications 65 psi is enough flow but injectors are needed as the 480cc just aren't flowing enough. another problem is maintaining the higher psi which a bigger fuel pump is then needed.
sadly theres no single part to fix the issue
Old Apr 26, 2014 | 07:09 AM
  #44 (permalink)
So, on your dyno pulls, were there significant improvements in HP?
Old Apr 28, 2014 | 05:00 PM
  #45 (permalink)
boostmonkey's Avatar
I had Boostmonkey weld the rear fitting on my spare rail and his work looks great. Thanks!
Thanks! Did you get it installed yet?
Old Apr 28, 2014 | 05:03 PM
  #46 (permalink)
Thanks guys!
Old Apr 28, 2014 | 05:30 PM
  #47 (permalink)
+43 RWHP and +52 RWTQ
Of course the power improvement was really from the tuning and from the increased boost (21 psi) which the fuel system upgrade allowed me to run without running lean.
Old Apr 28, 2014 | 05:34 PM
  #48 (permalink)
The regulator has a 1:1 vacuum/boost reference port, but I am not using it. I am running a fixed fuel pressure like the stock setup. A little higher though at 65 psi.
You have it right with the fuel flow. I made a quick little sketch of my fuel system flow diagram to help visualize it.
Old Apr 28, 2014 | 05:35 PM
  #49 (permalink)
Interesting.....I am just now data logging and figuring out my system. This may be something we will try.
roar
Jun 15, 2022 11:46 AM
Ed Mahoney
Other Cars Etc
Sep 21, 2015 10:42 AM
RacerXofFL
Sep 15, 2015 05:00 PM
81's
Sep 13, 2015 04:34 PM
RiderJC
Sep 7, 2015 11:19 PM
