Old Jan 6, 2014 | 06:02 PM
onehundred80
Default Re: My locks don't lock using the lock/unlock button on my dash (trunk won't unlock!!
Originally Posted by Mrmiata
Well there is still water in the trunk at this point.. Mark.. got any photos of that rubber plug that needs a hole put in it since the trunk won't open at this point?
What part of Texas? There are some friendly Texans on this board..might talk into some help..
See this post on the troubles this member had, his was light problems, but the cause is the same - water in the trunk.
This problem can occur when the yellow plastic lines to one or more locks become brittle and break, in which case you should be able to hear a slight hissing noise when the lock buttons are pushed.
Here's a pic of the trunk showing pump and plug.
