Old Jan 6, 2014 | 07:31 PM
Mrmiata's Avatar
Mrmiata
Default Re: My locks don't lock using the lock/unlock button on my dash (trunk won't unlock!!
I've never owned a coupe. If the Roadster trunk jams, you just open the top enough to crawl into the trunk and work on it upside down on your back. I had to do that when my Roadsters electric lock jammed.
But the coupe is a totally different design....
Miata - not sure what you are referring to.
Thinking about it.. maybe it was Graphite Ghost that mentioned there are two rubber plugs on the bottom of the car in the trunk area..use an exacto blade and slit for water drainage.. I've got some pics of I think Andrews car with the bumper cover removed.. there is one little hole in the metal pan behind the bumper.. think you would have to know what your doing if that is the access point for "manual" release..
