Thread: intermitentes
Old Jan 8, 2014 | 10:26 PM
pizzaguy
Default Re: intermitentes
Originally Posted by rekcah
It's the relay under the fuses in the fuse box in the engine compartment. I had this same thing happen and took 3 yrs to figure out. Only one side of the relay is making contact that is y only one side of lights flash. I took it out used a little bit of 1000 grit sandpaper to clean it a bit and also slightly bend the contact. It's been working perfectly for the last few years.
Search the forum for something like siren with lock unlock. It will show the relay in question.
I'm on my phone now or I would give a link.
Ok, but what about his last complaint, that the system won't lock with the key?
(Actually, Im not sure if he means it wont lock with the key fob, which is how I read it - or if it means it won't lock all locks with the KEY in the DOOR - which, I believe, doesn't happen anyway.)
