onehundred80
You are looking at a fault that involves the SKREEM, it will allow you to try and start the car three times, if the security system does not receive the correct signal from the key chip the car will not even attempt to start again. Disconnecting the battery erases the memory of the no start and lets you try again.
Most problems are because the SKREEM unit has failed. Another cause would be the halo ring around the ignition switch failing or it has become disconnected from the SKREEM. Yet another reason would be the wrong key or a missing chip or faulty chip inside the key fob.
+1
Unless someone just did the sticky key mod and left the ring disconnected, this will be a trip to the dealer.
And OH how I hate to say that....
