Old Jan 24, 2014 | 02:51 PM
maxcichon's Avatar
maxcichon
Default Re: Replacing factory head unit.
Originally Posted by B1gfun
thinking about this one:
2014's BEST Deal On Kenwood KMR-D358 Marine Stereo!
I ordered some 250 crossovers and will install them to the fronts just as the "biggest bang for the buck" thread suggests. Those should remove some of the lower frequencies and improve clarity to the highs right?
i should just use the front speaker wires from the new stereo and not the rca's to the factory amp correct?
If i use the sub woofer rca out from the aftermarket unit I should be all set to add another amp correct? (no crossover needed?)
Correct on all 3 points. This is what I'm in the middle of myself.
I was going to start a thread asking where the most convenient firewall feedthrough is for tapping 12V near the battery. Is there any hole available besides the one for the ECU box wire bundle? I'll (and you should too) be running a separate 8 gauge 12V + to the power distribution block in front of the ECU box, and I haven't looked to see where i'm running it!
