Old Feb 24, 2014 | 06:41 PM
  #665 (permalink)
pizzaguy
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by Crossbow34
I just finished the sticky key fix. What a great help this forum has been. My thanks to all
When I was putting the ignition housing back in, I dropped a small spring out of the plastic insert.
In the attached photo, the yellow arrow points to the plastic insert and the red arrow points to the small spring.
I cannot figure out the purpose of the spring or if I've even put it back in the right place
Any suggestions?
Best regards,
Pete
By the way, this is not the same spring that I was trying to remove to solve the sticky key. This spring fell out of the barrel of the ignition housing as I was hammering away with a punch (as suggested) to get to the "problem" spring.
It has been 3 years, almost 3 years and one month in fact - and I sure can't remember that spring.
BUT AGAIN, I keep telling people that you should fix the thing BEFORE it locks up for reasons like this.
Hopefully, your experience will convince someone to fix theirs before it actually locks up.
