Old Feb 27, 2014 | 06:25 PM
Franc Rauscher
Default Re: Engine Died at High Speed
Originally Posted by Padgett
DFCO should have prevented the throttle from shutting too fast, its an emissions thing. More likely it hit an undefined region in one of the maps and the PCM became "confused". Had a tuner been in there ?
Thank you.
My explanation would have been similar. As the throttle backed off, the injectors shut down. System went lean and the ECM shut it down. Or the engine starved. Given the over the ground speed, the ECU said abort.
Same thing could happen to a totaly mehanical carbuerated engine.
One other possibility would be an over rev situation where he pushed in on the clutch, left his other foot on the throttle, the engine over rev'd to the limiter, and the engine shut down. Depending on what the driver did with the throttle it stayed that way.
