Engine Died at High Speed
Old Feb 27, 2014 | 07:29 PM
Default Re: Engine Died at High Speed
Thank you.
My explanation would have been similar. As the throttle backed off, the injectors shut down. System went lean and the ECM shut it down. Or the engine starved. Given the over the ground speed, the ECU said abort.
Same thing could happen to a totaly mehanical carbuerated engine.
One other possibility would be an over rev situation where he pushed in on the clutch, left his other foot on the throttle, the engine over rev'd to the limiter, and the engine shut down. Depending on what the driver did with the throttle it stayed that way.
I'm still waiting for the explanation of how the car gets too much air into the cylinders.
Old Feb 27, 2014 | 08:09 PM
And I am waiting for you to understand the obvious.
But then, You have never driven a car at those speeds, or pushed and engine that hard,,,, have you?
Engineering is done in the comfort of the office. Real world tends to be differ't.
That's why Bridges sometimes fall down.
And engines blow up.
And the engineers learn.
I cannot take any credit for the concept. A Tuner here in town who races minis suggested the idea. I say it seems logical.
Old Feb 27, 2014 | 08:44 PM
Tell me about it. I've been dealing with consulting engineers who have never actually worked on the systems I deploy. I can't tell them a damn thing.
Now when their egos don't allow them to.
Old Feb 27, 2014 | 09:00 PM
I was an installer for years. Been there.
Old Feb 27, 2014 | 10:45 PM
I have to admit I have not gone at those speeds as I am not half the macho man you are and I must be extremely dense as well, as I cannot understand how too much air gets into the cylinders of a car that is idling.
Please explain it to me with pictures if possible.
Old Feb 28, 2014 | 08:23 AM
Padgett's Avatar
The one piece we are missing is whether a tuner had been in there. My owner's manual calls for Z-rated tires (149 mph) so at 144 the speed limiter should not have kicked in with the factory program. OTOH if that was read from the speedo, who knows what the computer thought the speed was. Have not seen a disassembly but in my GM computers there is a fuel cut off speed and a turn back on about 5 mph lower.
Also there is " The traction control indicator turned on and the color was orange (not yellow). All other warning lights came on while the car was in-gear." but no CEL or codes ? That sure sounds like the computer crashed and reset when started.
ps Have been at or over that speed many times (used to race Corvettes). Am more concerned about tach, oil, and temp than speedo.
mobilefitt
Nov 8, 2015 08:30 AM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
ricardo 53
Jul 21, 2015 07:49 AM
Valk
Jul 20, 2015 08:17 AM
