Old Mar 1, 2014 | 08:46 PM
onehundred80
Default Re: Full OEM style push start ignition and start!
Originally Posted by Selbyl
Mr. 180 I'm trying to recreate the push start system that is shown in this thread but the creator is very hard to get a hold of. How would I go about installing a push start button that will turn the car to on (without starting the engine), start and off with one button?
I think I have figured out the on/start conundrum, the car will not start unless the clutch pedal is pushed in. So the position of the clutch determines whether or not the car is starting. As for pushing the button again to turn the car off, I'm a little bit at a loss.
By using the Dei 2021T I've figured out how to get the car to lock/unlock and arm/disarm the alarm. Also having this device tap into the start button the car will only start if the fob is within range.
The cool spoiler pop up feature I'll have to figure out later.
It will be a few weeks before I install this set up but I'll be sure to do a full write up and try to have some pictures to help out people who want to install something like this.
Any help with wiring diagrams would be much appreciated.
I do not know anything about what you are trying to do and I would not even attempt it if I did.
I can be of no help. What the OP did seems to take more time than a key.
We had push or pull starts back in the day and welcomed the key start, we have gone full circle.
