Thread: P0123
Old Mar 7, 2014 | 12:22 PM
onehundred80
Default Re: P0123
Originally Posted by Mrmiata
Actually not my pic (can't have someone getting sideways.. LOL). But "you are correct". Vice grips or channel locks will let you "back and forth twist" on the vane till it breaks loose.. then a dremel to carefullly smooth it out.
The issue as best I can tell has nothing to do with the tune or not tuned. I noticed my car would sometimes "hang" an extra second at 1500 rpm when coasting to a stop. It's somewhat hard to notice on automatics, but I'm sure real noticeable with a stick. They seem to just eventually work through it though.
Oh.. "noob questions"... You did your homework and sought out the information! So any gray area questions you have are more than welcome..
I would add that I did not remove these baffles because having some knowledge of plastic molding I think over some period of time the removal may cause problems.
These ribs were molded and therefore support the sides to some extent. After removal the constant heat may induce some stress release of the remaining part. Could this lead to air leaks due to part distortion? I'm not sure and I did not intend to find out.
My two cents for what it's worth. Who said not much?
