Re: Help!!!!!
UK-SRT6
Anyone come across this! 05 SRT-6.
Accelerate quite hard, revs got high, box does not select any gear, goes to neutral tho gear indicator is still on D. Stop turn engine off, restart all is fine until hard accelerate again!!!!!! and it does the same again, at one point was stuck in 1st gear box would not change up!!
Any help would be appreciated.
My first thought is it is the dreaded Limp Mode feature in which case it would be probably be stuck in second. This feature is to prevent damage to the transmission while you drive it. The problem is generally to be found in the electrical or solenoid plate. Speed sensor or solenoid failure.
