Old May 4, 2014 | 12:00 AM
  #44 (permalink)
JEFASOLD's Avatar
JEFASOLD
Default Re: STACKED PULLEYS RESULTS! DYNO and 1/4 MILE!
Originally Posted by Billy22Bob
When a gas expands without doing work - it cools - cockpit evaporator in your AC
When a gas is worked on to compress - it heats - front condenser in your AC
Yesterdays comment was "off the cuff", I just went back into my calc. sheet to confirm.....luckily I wasn't too far off. I even impress myself sometimes....
See attached comparison of OEM v NWDCAI
for stock pulley setup and 14.5psi MAP at WOT and 6200rpm
L8tr - PS - I cant recall where I got the Throttle body drop from but I do recall it was guestimated at WOT somewhere to be about 1psi through the 74mm body. My calc sheet was set up to allow this to be changed to 80-82mm if need be.
Obviously these numbers would be accentuated with the larger cfm's that a pullied setup would impart.
And it works on a squared function - so increase cfm by 10% and you increase the pressure drops by 21% and the temps go lower again.
And - this lower value should be the pressure used when calculating your Pressure Ratio....MAP/SC Inlet pressure
Ok, good enough for me, thanks and sometimes you impress me. That isn't easy to do!
