Old May 8, 2014 | 11:43 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: SRT6 Fuel Pressure setting with AEM Pressure Regulator???
I've been told the stock regulated filter limits pressure at 54 psi.........but I didnt have a built-in pressure gauge installed with the stock filter to verify that.
Before I installed my fuel regulator, I installed the extra gauge in the engine bay and with the stock filter-regulator but with the SL55 pump, I was reading 58. I need to get a hose to connect the vacuum line and then I will be finished with the install. For some reason my regulator came without any hoses or clamps whatsoever. Fortunately, I had some fuel line from an old regulator that I had lying around, so a trip to NAPA and all should be well. Good to hear that we may not need injectors, that will make my day.
