boostmonkey
Just to be clear: you can install the 65mm
OR 178mm pulley without supporting fuel system upgrades. To do both, you need some upgrades.
For 178/65 stacked, I recommend
at least the following fuel mods:
- upgraded fuel pump
- upgraded fuel pressure regulator & filter
- looped fuel rail
- 550cc injectors
- WBO2 or dyno-tuned with WBO2
I also have:
- larger fuel lines
- reworked fuel fail with larger inlet
- conversion from return-less to "regular" return style rail
For intercooling I recommend
at least:
- IC pump upgrade
- heat exchanger upgrade
And seriously consider other intercooling upgrades such as:
- Rudy's single-pass IC
- IC insulation (baked potato mod)
- IC reservoir (think of it as a heat sink)
Switching from a 62mm pulley to the stacked pulleys and getting a Eurocharged tune gained me +43 RWHP and +52RWTQ.
HI Matt
I am considering stacking, And I was wondering if you think I could be successful without the looped rail, as I just installed new injectors & tune to fix my lean problem. Also can you tell me what WB02 is?
Thanks Barry
