Old May 11, 2014 | 10:29 AM
  #59 (permalink)
JEFASOLD's Avatar
JEFASOLD
Default Re: STACKED PULLEYS RESULTS! DYNO and 1/4 MILE!
Originally Posted by boostmonkey
Just to be clear: you can install the 65mm OR 178mm pulley without supporting fuel system upgrades. To do both, you need some upgrades.
For 178/65 stacked, I recommend at least the following fuel mods:
  • upgraded fuel pump
  • upgraded fuel pressure regulator & filter
  • looped fuel rail
  • 550cc injectors
  • WBO2 or dyno-tuned with WBO2
I also have:
  • larger fuel lines
  • reworked fuel fail with larger inlet
  • conversion from return-less to "regular" return style rail
For intercooling I recommend at least:
  • IC pump upgrade
  • heat exchanger upgrade
And seriously consider other intercooling upgrades such as:
  • Rudy's single-pass IC
  • IC insulation (baked potato mod)
  • IC reservoir (think of it as a heat sink)
Switching from a 62mm pulley to the stacked pulleys and getting a Eurocharged tune gained me +43 RWHP and +52RWTQ.
Did you replace all the fuel lines from the pump to the rail? That's a pretty big job.
