Old Jun 23, 2014 | 11:36 PM
onehundred80
Default Re: alternator failure
Originally Posted by fastfred
is that right i believe what you say but no one has said anything like that ...yes its a BOSCH...and when i called the seller a big co. they said direct replacement all you have to do is change from the 6rib to the 8rib...can someone chime in on this I'm not to good at wiring??? i read a lot of posts and did not read that maybe something i missed??? thanks fo the heads up...
Here is more proof of the wiring issue. (CLICK)
The plug can be changed from your old one.
I said in post #2 you should check, and I did say in post #5 you need a Valeo. Maybe I should have been more specific.
