Old Jun 26, 2014 | 04:42 PM
  #707 (permalink)
ijaved's Avatar
ijaved
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by tednite
Thank you forum persons. I too was able to get everything apart and even removed the key cylinder but was unable to get to the pin to remove it and the spring. This is odd but half of the screws from the listings had apparently already been removed! I think I have a hybrid where someone put an SRT, fixed wing body on a Crossfire coupe because I don't have super-charger, the speedometer max is 160. And I have a 6-speed manual tran. New blue-tooth radio had been added, suede and leather seats, rear back up camera, and a Viper alarm system.
I say all this because I got it all reassembled and it doesn't stick anymore. However, my dash display light, does not work, nor the turn signals, or the rear view camera. So, because I have to check everything, anybody have an idea if there is a single source that I should look for?
Sorry didn't read your post fully. Looks like you have a short somewhere. Check the fuse and if they check out then backtrack on disassembly steps and see if you might have accidently pulled a wire from the awesome setup you have
I think the fuse you are looking for it ""Electronic Transmission Control (Park / Reversing Lock) and BCM" (This is number 7 in the underhood fuse box on the driver's side.) taken from post by pizzaguy
https://www.crossfireforum.org/forum...tml#post516266
Someone more advance can shed more light on the issue I think.
